borrbr
Installation with user's choice
Hi
I'm creating a project for a files installation.
There is a file that will be copied according to the user's choice.
The user chooses the country of installation and the file for his country is copied from a shared folder.
But during installation, these files are not copied.
Here's how I set it up
Properties
  • Share : a folder containing the files to be copied (file_FR.txt ; file_CN.txt ; file_PL.txt)
  • SITE : FR (by default)
Dialog
  • Radio button group :
    - With 3 choices FR; CN; PL
    - Property name : SITE
    - For the France radio button : Value = FR
Files and Folders
  • A folder "property based" : Share
  • One folder FR, one CN and one PL : "Install folder content into ..."
In each folder one file :
- New file operation ; Copy/Move
  • Source File
    - Name : the original name of my file : file_FR.txt
    - Folder : Share
  • Destination File
    - Name : file.txt
    - Folder : APPDIR\...\FR
  • Properties
    - Component : Files
    - Execute on : Component installation
    - Condition : SITE = "FR"
    - Operation : Copy
Idem with CN and PL with the corresponding parameters.
What am I doing wrong?
Thanks a lot
Test.aip
My test project
(19.04 KiB) Downloaded 445 times
Re: Installation with user's choice
Please note the File Copy/Move operation is intended for files outside the package only. If you need to duplicate files included in the package, you can use a file duplication operation instead.
However, there is no need for the duplicate operation.
1. You just need to add the files as regular files in the desired folders and condition their component.
2. Use the F8 or the Go to Component toolbar option after you select the file that you conditionally want to install.
3. Condition the component installation through the Condition field from the Component properties.
file condition.png (45.84 KiB) Viewed 4600 times
Attached you can find your modified sample project. You can also check the Conditionally copying installed files to APPDIR based on installation language forum thread which debates the same scenario.
sample.zip
(4.51 KiB) Downloaded 214 times
borrbr
Hi Liviu
Thanks a lot, I will try this.
Regards
borrbr
My files are outside the package.
These files are located in a shared folder on the server.
The files need to be included in the package in order to be installed by your setup. You can try using the Synchronized Folders feature.
If that does not help you and you need to duplicate files included in the package, you can try using a file duplication operation instead of the File Copy you used.
