MGS
Translation Setting - Inherit Global Settings
Where can I change the default translation setting? In the UI it says here: "Specified in the languages tab of the Translation page."
But I could not find it so far at the described location:
I found out that my installer shows a different title, due to the translation of the [ProductName] being something that I never set myself. To fix that, I temporarly set it to "Never translate this string", but that can't be the solution that I have to do this for all AI-specific properties that you developers pre-use in the program.
Johannes
Re: Translation Setting - Inherit Global Settings
Hello Johannes,
In the meantime, the UI seems to have been changed, but we did not update the option - please accept my apologies for that.
I will create a ticket so that can be fixed in the future.
The "inherit global settings" from the Localization Dialog article can be found under "Project Strings" tab --> under "Translations" --> click on "Select...".
MGS
Apology accepted! Thanks for the clarification, will try this out ASAP, and also thanks for creating the ticket. :)
Johannes
You are always welcome, Johannes! :)
