Hello Scott and welcome to our forums,
Firstly, amazing tool, loving it so far.
Thank you for your kind words!
Let's discuss a bit your scenario here to see what options we've got on our hands.
These two products that you are creating, are they related in any way? For instance, do they share any resources, such DLL files for example?
If these products are completely different, we can still make a single MSI out of your two projects.
What I'm thinking is the following:
- in the
"Files and Folders" page, we have two folders, one for each project
- after building the solution containing our two projects, we can synchronize the folders from Advanced Installer with the ones from disk
Working with Synchronized Folders
If you still would like to have them as separate products, then we can still build them both and then add them to a suite installer.
Creating suite installations
One advantage of this would be the fact that they can be installed/uninstalled separately without depending on one another.
Now, going back to the solution you have found, our "project solutions" support.
What this support does is basically similar to Visual Studio, where you can have a single solution with multiple projects. Same with our support, you have one solution with more than 1 Advanced Installer project and of course, each of this project has its' own output (in our case, installation packages in the form of MSI or EXE).
