To whom it may concern,
I have built an Advanced Installer script that uses a bunch of properties; I have set defaults for those properties, and if I build my installer package from within the UI, it works, building my installer executable.
But I want several of these properties to be configurable via the command line so that I can parameterize my script for different branches, versions, etc. without having to edit the script for each variant. When I run the following command line trying to set a bunch of those properties according to the documentation I've found, all I get is a popup that shows me "usage" without explaining what I am doing wrong.
Here is my command line:
"C:\Program Files (x86)\Caphyon\Advanced Installer 22.3\bin\x86\advinst.exe" /build "d:\ncs\install\SUS.aip"
/SetProperty _NCSVER_="11.7" /SetProperty _NCSFULLVER_="11.7" /SetProperty _NCSDISPVER_="11.7" /SetProperty _NCSSHORTVER_="117" /SetProperty _NCSFORMATVER_="305"
When I run this, all I get is an unhelpful popup, giving me the command line syntax, which I am trying to follow, but no indication of what it doesn't like about my command line.
Is there a way to find out what it doesn't like, and is what I'm trying to do possible?
/Will Sadkin
