Hi Sean,
What you need can be done in multiple ways:
1) Use the
Registry page to create a registry value for each language. Since the values will have the same names, you can use the approach explained in the
Install 32-bit/64-bit registry entries how-to (property-based registry keys). After the registry entries are created, you can use the
Organization page to condition the installation of their components.
In the "
Condition" field of the
Component Properties page you can use the
ProductLanguage property. For example, the condition of the English registry value can look like this:
Note that "1033" is the language identifier of the English language. You can find a list of language identifiers
here.
2) Another approach is to use a
custom action. This custom action can verify the
"ProductLanguage" property and based on the result it can write a registry value.
Here you can find some sample VBScript code for creating a registry value. Note that in VBScript you can get the value of a property by using the "Session" object:
dim languageID
languageID = Session.Property("ProductLanguage")
After retrieving the language identifier of the installation language, you can compare it with known values and set a variable. When all known values are verified, you can write the variable into the registry.
If you have questions about these approaches, don't hesitate to ask.
Cosmin
