castanog
Mixed 32/64-bit
I need to make a Mixed 32/64-bit MSI for a project, I bought the Professional version, because it clearly stated on the purchase page http://www.advancedinstaller.com/purchase.html that the professional version sported Mixed 32/64-bit.
I'm using version 11.0 and the options available under the Install package type do not show a Mix option.
Looking at the FAQ I saw that only the Enterprise version support it.
Is this so?
Did I just trow away $300.00 USDLL?
Is this a misrepresentation of the Advance Installer features as shown on the Purchase page?
I'm desperate, my client is demanding a 32/64bit install file and I can not afford the $1000.00 Enterprise version.
Re: Mixed 32/64-bit
As our Top 20 Professional Features article says, the Mixed 32/64-bit installers feature is available in the Professional edition of Advanced Installer.
When the "Mixed 32/64-bit matching the platform" package type is selected in the Install Parameters page, then the wizard will launch and will guide you step by step through every stage required to organize your “Mixed 32/64-bit matching the platform” package, as it can be seen in the below image:
Just make sure you select the Professional template in the Start Page of Advanced Installer.
Here is an article which may be useful to you: How do I create a package that will be installed like a 64-bit package on 64-bit platforms and as 32-bit package on 32-bit platforms ?.
This easy approach is to use the Mixed 32/64-bit matching the platform wizard.
castanog
Re: Mixed 32/64-bit
Dan, Thank you for your answer.
I was able to make the 64/32 bit installation, my issue was that I had not selected the "Professional" template (Not very intuitive on your interface).
Still I found that I could not create a MSI files, the only way I could make a Mixed instalation was creating and EXE file. Is this normal?, Did I missed something?
Re: Mixed 32/64-bit
Indeed, the Mixed 32/64-bit matching the platform package type require the .EXE setup file.
